Getting Started
Oasis montaj is designed for multidisciplinary and collaborative exploration, providing access to all your data along with a powerful suite of mapping and analysis tools in a dynamic 3D environment. With Oasis montaj, you can process, map, quality-assure (QA), and interpret your ground and airborne survey geophysics, geochemistry, and geology data.
To get started, follow these steps:
Once you've completed these steps, explore the Overview of Oasis montaj for insights into key components and features, and take a Tour of Oasis montaj to help you get started.
Software and Hardware Requirements
For recommended hardware and software requirements, go to Oasis montaj and Target System Requirements.
Installing Oasis montaj or Target
You can download the latest version of Oasis montaj from MySeequent.
To install Oasis montaj, ensure that you are logged in as an Administrator. Users must have Power User privileges to run the system—contact your local IT administrator to obtain the necessary permissions.
To enable the internet capabilities in Oasis montaj, Internet Explorer 9.0 or later must be installed. However, this does not mean Internet Explorer must be your default browser; Oasis montaj simply uses the internet connection technology provided by IE9 to establish connections.
Oasis montaj requires specific settings (SET GEOSOFT, SET GEOTEMP) and inclusion in your DOS path. If these settings are not already present from a previous installation, they will be automatically configured during setup.
Signing In to Oasis montaj or Target
When installing a Geosoft desktop application (version 9.0 and later), you must sign in using your Seequent ID. Additionally, licensed applications require an active subscription.
For details on setup and requirements for the latest release, refer to Signing In to Oasis montaj.
Sample Data
Sample datasets are available to help you explore new software features and follow guided paths and individual courses in the Seequent Learning Centre. To access the data files referenced in various sections of Oasis montaj or Target, visit lms.seequentlearning.com, navigate to the Resources tab, and filter by:
  • Type = Archive
  • Category = Oasis montaj
You'll find the Oasis montaj Sample Data folder listed and ready for download.
For best practice, copy the data into a separate "working project" folder before opening or modifying it. This ensures you always have a clean original copy.
Configuring Oasis montaj Settings
Before getting started, you may want to configure your Oasis montaj settings. Click here for a description of the available settings and customization options.
