Import ArcGIS MXD as Map
Use the ArcGIS Tools > Import ArcGIS MXD as Map menu option (geogxnet.dll(Geosoft.GX.SaveMXDAsMap;Run)*), to import an MXD file as a Geosoft Map (*.map) file.
This functionality is only accessible on systems where a licensed copy of either ArcGIS Desktop or ArcGIS Desktop Engine is installed.
Import an ArcGIS MXD as Map dialog options
MXD name |
Browse to locate the ArcGIS MXD file to import as a Geosoft map. Script Parameter: ARCGIS_SAVEMXDASMAP.MXD |
New map name |
Specify the new map name. Script Parameter: ARCGIS_SAVEMXDASMAP.MAP |
Only the currently visible layers in the MXD will be saved to the map. If the MXD window is in Data Frame mode, only the visible layers in that frame will be saved to the map.
During scripting, the following parameter can be used to select whether only the current data frame or the whole MXD should be saved:
Extra Script Parameter: ARCGIS_SAVEMXDASMAP.FOCUSMAP - 1 or 0
