Plot Colour Range Classified Symbols
If you do not require the more advanced scaling functionality provided in the COLSYMB GX, you may choose to plot simple coloured symbols. Use the Colour Range Symbols option to specify symbol plotting parameters and plot classified symbols on your map.
The Colour Range Symbols option is available in the following menus:
Map Tools > Symbols (CLASYMB GX)
Geochem Map > Point Plots (CHCLSYMB GX)
Euler 3D > Plot Solution Symbols (CLASYMB GX)
There are six dialogs with this GX.
Colours can be based on a variety of colour files, including zone (*.ZON), aggregate (*.AGG) or image transform (*.ITR) files. Plotting parameters include:
- Classification channel
- Number of ranges
- Symbol font
- Symbol weight
- Symbol edge colour
- Symbol angle
Colour Range Symbols dialog options
Classification channel |
Select channel to plot from current database. |
Number of ranges |
Number of ranges to plot, 1 to 12. |
Mask channel |
Select a mask channel from the drop-down list. If the use of the mask channel is enabled and set to this channel, only those data values whose corresponding mask channel values are not dummy values will be plotted or exported.Channels must have their CLASS attribute set to MASK to appear as selections in the drop-down list. If the mask channel does not exist, it will be created with its CLASS attribute set to MASK. |
Symbol font name |
Specify the symbol font name. |
Symbol weight |
Symbol weight, 7 weights are available "Normal" (default). |
Symbol edge colour |
Symbol edge colour, black by default. |
Symbol angle |
The symbol angle (in degrees clockwise) |
[Plot] |
Click this button to create the Colour Range (Classified) Symbol plot on your current map. |
[Ranges] |
Click this button to display a dialog for setting ranges, symbols, sizes and colours. |
[Files] |
Click this button to display the Load/Save to ITR File dialog for saving settings to an ITR file. Script Parameter: CLASYMB.ITR [The name of the ITR file used for initial settings] |
Specify Ranges dialog options
Maximum value for level 1 |
Specify maximum value for level 1 (lowest level) Additional levels must have values which increase or equal previous level. . |
Maximum value for level # |
Specify maximum value for level #. |
Maximum value for level n-1 |
Specify maximum value for level n-1 (highest level). |
[Symbols] |
Click this button to display the Specify Symbols dialog for setting symbols for current ranges. |
[Sizes] |
Click this button to display the Specify Sizes dialog for setting the symbol sizes for current ranges. The sizes must be greater than zero. |
[Colours] |
Click this button to display the Specify Fill Colours dialog for setting the colours of the symbols for the current ranges. Note that many of the symbols have no fill. |
This GX uses the classification channel’s register to store the additional symbol information. The ranges are specified in the same manner as for an ITR file. If there are n ranges, then n -1 maximum values are specified, because range n applies to all values from the maximum value specified for range n -1 to "infinity".
The CLASSLEG GX can be used to plot a legend.
Plotted data is masked to the current data view’s clip region. Data outside the clip region is still written to the map, but is not visible. To see this data, uncheck the "Masked to view" box in the Map Manager tool.
If you are plotting symbols to a data view that is not oriented in 3D, the current X, Y channels must be set in the database.
If you are plotting symbols to a 3D oriented view, the current X, Y and Z channels must be set in the database. Symbols plotted to a 3D oriented view are projected to the section plane irrespective of the section thickness.
