Merge Databases
Use the DBMERGE GX to merge the contents of one or more databases into another. The option is available with the following menus:
  • Database > Import > Geosoft Database Merge
  • Database Tools > Database Utilities > Merge Databases
Merge Databases dialog options
Database to modify
Specify the name of the target database. The current database is selected by default.
Script Parameter: DBMERGE.GDB1
Database(s) to merge
Select one or more databases to merge into the database to modify.
Script Parameter: DBMERGE.GDB2 (separate multiple items with the ‘|’ character.)
Lines/groups to merge
Choose from one of the two available options:
  • "Selected": only the lines selected in the database(s) to merge will be merged.
  • "All": all lines will be merged.
Missing lines in the database to modify will be created during the merge process.
Script Parameter: DBMERGE.LINES
Channels to merge
  • "Displayed": only the channels currently displayed in the database(s) to merge will be merged.
  • "All": all channels will be merged.
Missing channels in the database to modify will be created during the merge process.
Script Parameter: DBMERGE.CHANNELS
Replace existing data?
Decide how data is merged into the database to modify:
  • Select "Yes" to replace any data that exists in the database.
  • Select "No" to only merge data into the channels that contain no data.
  • Select "Append" to append data to the end of existing data.
Script Parameter: DBMERGE.REPLACE
