Digitize Targets
Use the Digitize Targets dialog (DIGITPROFOP GX/DIGITPROFOPT GX) to view or modify the current settings for the target list, output channels, and symbols.
The dialog is activated from the database profile window by clicking on a position in a channel profile and selecting the Target Selection Options or Select Target context menu items.
Digitize Targets dialog options
Target list
The name of the "group" line used to save data.
Script Parameter: DIGITPROF.TARGETS
Channel to save value
The value from this channel is copied to a channel with the same name in the targets group line. This channel does not need to be the same as the one displayed in the profile.
The "current" X and Y channels are not available in the drop-down channel lists because they are output automatically.
Script Parameter: DIGITPROF.CHAN
Channel #2 (optional)
Channel #3 (optional)
Channel #4 (optional)
Select up to three additional channels whose values will be saved to the target list.
Script Parameter: DIGITPROF.CHAN2, CHAN3, CHAN4
Plot symbol on current map?
If Yes, the selected target is plotted on the current map at the corresponding X, Y location. By default, no symbol is plotted.
Script Parameter: DIGITPROF.PLOTSYMB (0: No, 1: Yes)
[Symbol]
Select the Symbol button to define (or redefine) the symbol for plotting.
