Re-Fid a Channel to a Distance Base
Use the 1D FFT > Advanced Settings > Re-Fid to Distance menu option (DISTFID GX) to create a distance-based channel from a fiducial-based channel.
Re-Fid to Distance dialog options
Channel to re-fid
Select the data channel to be re-sampled.
Script Parameter: DISTFID.IN
Distance sampled output channel
Specify the new distance-based channel.
Script Parameter: DISTFID.OUT
Distance increment
Enter the required distance increment. If not specified, the nominal data spacing will be used.
Script Parameter: DISTFID.INCR
Maximum distance gap to interpolate
Define the maximum distance gap to interpolate. Gaps larger than this value will not be interpolated.
Default: 1.5 × nominal data increment
Script Parameter: DISTFID.GAP
Interpolation method
Choose the interpolation method: Minimum Curvature, Linear, or Akima.
Script Parameter: DISTFID.METHOD
This GX uses a channel named _Distance as the reference for distance. If this channel does not exist, the X and Y channels are used to create a _Distance channel, which contains the cumulative down-line distance starting at 0.
If you prefer to use a different reference channel (e.g., X or Y directly), copy the desired channel to a channel named _Distance before running DISTFID GX.
The new channel should only be viewed or processed alongside other distance-based channels.
