Make Distance Channel
Use the Database Tools > Channel Tools > Make Distance Channel menu option (geogxnet.dll(Geosoft.GX.Database.DistanceChannel;Run)*) to calculate a distance channel from provided X and Y, and optionally Z channels.
Make Distance Channel dialog options
A common Oasis montaj function is to calculate a distance channel from specified X and Y channels. When you use this functionality, the system assumes that the first point on each line is at distance 0 and subsequent points are calculated from the cumulative distance down the line. The distance channel is calculated as if a measuring tape is laid down along the path.
The X and Y channels are assumed to hold the coordinates of a normal Cartesian system.
In order to maintain consistency with the outcome of the previous 2D distance channel GX, the Z channel is optional and does not get auto-populated. Even when set in the database, you have to select the Z channel in order to calculate the 3D distance.
This tool uses the same parameter space variables as the pre-existing distance GX (distchan.gx) and has replaced it in the Database Tools > Channel Tools menu; as a result pre-existing scripts will be honoured.
Maintain line direction
Use cartesian coordinate system
