EM Noise Rejection
Use the EM Utilities > Reject Noise option (geogxnet.dll(Geosoft.GX.EM.NoiseRejection;Run)*) to remove noise from the EM decay arrays. You must first run the EM Noise Calculation option.
Noise Rejection dialog options
The calculated standard deviation of each gate is saved in the registry of the array channel for further use.
Apply this tool with care. The noise rejection is an iterative process. You can start with the standard deviation of each gate as the noise threshold. After applying it, inspect the profile of each filtered gate to see if you have attenuated the noise adequately. If the noise threshold is incorrect, you may have accentuated the noise instead of attenuating it. Generally, one standard deviation will not be an optimum noise threshold for all the gates, and it will require adjustment. Once you have adjusted the noise for all the gates you can cut/paste from the “Noise values” window to a file and save it.
