Export 3D View to OMF
Use the 3D view > Export 3D View to OMF menu option (geogxnet.dll(Geosoft.GX.GEO3DV.Export3DVToOMF;Run)*) to create a new OMF file from selected datasets in the current 3D view. Once an OMF file has been created, it can be shared with a variety of other mining and geoscience software applications.
This tool can also be accessed from:
- The Export > OMF File menu option in the 3D Viewer
The Export to OMF context menu option in the Project Explorer
Export 3DV to OMF dialog options
Output OMF file |
Specify the name of the output OMF file. By default, the file will inherit the name of your current 3D view; however, you can override th default setting. |
Coordinate system |
The coordinate system saved with your 3D view parameters is displayed. All selected datasets to be exported will be "reprojected on the fly" to this coordinate system (see Application Notes). |
Coordinate system units |
The length units of the current coordinate system are displayed. |
Title |
Enter a title for the OMF file metadata. By default, the title will inherit the name of your current 3D view; however, you can override this setting. |
Description |
Enter a description for the OMF file metadata. This field is optional. |
Items to export |
The tree list displays all datasets contained in the current 3D view. Change the data to be exported by selecting or deselecting individual datasets. Hold down the Shift key to select or deselect multiple datasets simultaneously. At the bottom of the window, you can use the Select All or Select None buttons to manage your selections efficiently. OMF files support a variety of 3D geospatial datasets, including:
[Regrid Voxels] |
If the selected voxels are rotated or have variable cell sizes, you may need to resample them before exporting to your destination software. Click this button to open the Regrid Voxels for OMF Export dialog, where you can adjust the regridding parameters for the selected voxels. |
What is OMF?
The Open Mining Format (OMF) is an open geoscience exchange format for sharing 3D geospatial data within the mining industry. OMF provides a standardized file format for mining software, enabling files to be easily imported or exported between programs. It is specifically designed to represent spatial objects, including drillholes, block models, and surfaces.
OMF offers:
- The ability to easily share data between software packages.
- The capacity for companies to seamlessly share data internally or externally.
- A streamlined and efficient approach that eliminates manual or convoluted transfer processes.
When a new OMF file is created, it contains the selected datasets from the input 3D view. Once the OMF file is generated, you can share it with colleagues and stakeholders, allowing the entire 3D view to be shared as a single, cohesive package.
Reprojection
3D spatial datasets displayed in Oasis montaj or Target may have a different coordinate system from the 3D view in which they are displayed. As long as both the dataset and the 3D view have defined coordinate systems, the data will be "reprojected on the fly" and will be located correctly in 3D space. However, care should be taken not to mix datasets without defined coordinate systems, as this could result in mislocated datasets.
When exporting a 3D view to an OMF file, all datasets will be reprojected to a single coordinate system – the coordinate system of the 3D view. All data in the OMF file will adopt this one coordinate system.
Unsupported Data Types
While the OMF export supports most data types that can be displayed in 3D views, a few exceptions exist. Any layers that are not currently supported for OMF export are displayed in light grey text without a checkbox in the Items to export list.
Some of the datasets that are not currently supported for OMF export:
- Raster layers, such as:
- Images draped on elevation grids
- "Pixel plots" of section grids
- Azure Maps layers
- 2D and 3D vector datasets, such as:
- Drillholes
- Legacy vector layers, such as isosurfaces
- 2D and 3D ArcGIS Layer files (.LYR)
- Geostrings
OMF and the Global Mining Guidelines Group
The initial release of OMF in 2017 included support for basic structures, including points, lines, surfaces, meshes, and volumes. The subsequent version expanded functionality to incorporate block models.
OMF is a collaborative initiative developed under the guidance of the Global Mining Guidelines group (GMG). The GMG aims to foster broad industry engagement, which is crucial to the success of this endeavor. To support this goal, GMG has launched a global outreach program, including a sub-committee comprised of representatives from software vendors and mining companies. Together, they are shaping the future direction of the format.
For more information, go to:
Which software vendors and applications can create and/or import OMF files?
Several software vendors have already adopted, or are in the process of adopting, OMF as a standard format for exchanging mining datasets. These vendors include:
Vendor
Software
Deswik Deswik.CAD 2019 Dassault Systèmes GEOVIA Surpac 2019
MineSched 2019
Micromine Micromine 2020 Seequent (formerly Geosoft) Oasis montaj 9.7+
Target 9.7+
Seequent (formerly Aranz Geo) Leapfrog Geo 4.2+
