Continuation Filter
Use the Continuation option to apply a Fast Fourier Transform (FFT) continuation filter to a channel.
Continuation filter options
Continuation distance
(in ground units)
Continuation distance in ground units (> 0). Default = 0
Script Parameter: FFTCONT.DIST
Butterworth low-pass
(in ground units)
Low-pass cutoff wavelength for Butterworth filter. Default = 1
Script Parameter: FFTCONT.LP
Direction (up or down)
Direction for continuation: Up or Down. Default = Down
Script Parameter: FFTCONT.DIR
Downward Continuation
Used to enhance responses from deep sources by effectively moving the observation plane closer to them.
  • It is not theoretically possible to continue through a potential field source.
  • Short-wavelength signals can mimic shallow sources and must be removed to avoid high-amplitude, short wavelength noise.
  • To reduce noise, set the LP parameter to 1–1.5 times the continuation distance.
Upward Continuation
Considered a clean filter with minimal side effects, often used to remove or minimize the effects of shallow sources and noise in grids.
  • Upward continued data can be interpreted numerically and modeled, unlike many other filter processes.
Downward Continuation Filter
h: Distance (ground units) to continue down relative to the plane of observation.
Upward Continuation Filter
h: Distance (ground units) to continue up relative to the plane of observation.
