Apparent Density Calculation Filter
Use the Apparent Density Calculation option to apply a Fast Fourier Transform (FFT) apparent density filter to a channel.
Apparent Density Calculation filter option
Depth to the top of model
Depth to the top of the model.
Default: 1
Script Parameter: FFTDENS.DEPTH
Thickness of earth model
Thickness of the earth model in ground units.
Default: 1
Script Parameter: FFTDENS.THICK
Low-pass cutoff
(in ground units)
Low-pass Butterworth filter cutoff wavelength.
Default: 1
Script Parameter: FFTDENS.LP
Background density
(g/cm3)
Background density in g/cm3.
Default: 0
Script Parameter: FFTDENS.DENS
To ensure correct density units, the input data fiducial base must be in meters.
The low-pass filter can be used to remove noise in the data that would otherwise be amplified by downward continuation.
A low-pass cutoff of 1 to 1.5 times the depth is normally appropriate.
Apparent Density Filter
Parameters:
ω = wavenumber
t = Thickness (in ground units) of the earth model
G = Gravitational constant
d = Background density (g/cm³)
