Gaussian Filter
Use the Gaussian option to apply a Fast Fourier Transform (FFT) Gaussian filter to a channel.
Gaussian filter options
Standard deviation of function
(in ground units)
Specifies the standard deviation of the Gaussian function in ground units.
Script Parameter: FFTGAUSS.STDDEV
Low or high pass filter
Select Low or High pass filter. Default = Low
Script Parameter: FFTGAUSS.PASS
The Gaussian filter is a smooth filter commonly used for low-pass or high-pass applications. It provides gradual attenuation without sharp cutoffs, reducing artifacts such as ringing.
Gaussian Filter
Key Parameters:
k0: Standard deviation of the Gaussian function in cycles per ground unit.
(Similar to a cutoff, but the function amplitude at this point is only 0.39.)
0/1: Specify 0 for residual or 1 for regional filtering.
