Power Spectrum
Use the 1D FFT > Power Spectrum menu option (FFTPSPEC GX) to calculate the logarithmic power spectrum of a channel and save it to a new database.
Log Power Spectrum dialog options
Channel
Name of the input channel in the current database.
Script Parameter: FFTPSPEC.IN
Power spectrum output channel
Name of the output channel containing the power spectrum, saved in a new database.
Script Parameter: FFTPSPEC.OUT
[Set Sampling]
Click this button to open the Set FFT Sampling Parameters dialog. Use it to configure the channel’s sampling parameters and ensure the input data is properly sampled for 1D FFT.
  • The output power spectrum represents the natural logarithm of the power spectrum.
  • The fiducial increment will be expressed in cycles per original fiducial.
  • The profile is extended to a power of 2 times the length, and the wavenumber increment will be calculated as: 1/(Length * Fiducial Increment).
