Resistance Capacitance Filter
Use the Resistance Capacitance option to apply a Fast Fourier Transform (FFT) resistance capacitance filter to a database channel.
Resistance Capacitance filter options
Central wavelength cutoff
(in ground units)
Specify the central wavelength cutoff value in ground units.
Default: 1
Script Parameter: FFTRC.WAVEL
Low or high pass filter
Select whether to apply a Low pass or High pass filter.
Default: Low
Script Parameter: FFTRC.PASS
This filter is particularly effective for smoothing gravity data.
Parameter:
kc: Central wavenumber of the filter
