Reduce to Magnetic Pole Filter
Use the Reduce to Magnetic Pole option to apply a Fast Fourier Transform (FFT) reduction to magnetic pole filter to a channel.
Reduce to Magnetic Pole filter options
Geomagnetic inclination
Geomagnetic inclination in degrees. Default: 0
Script Parameter: FFTRPOLE.INC
Geomagnetic declination
Geomagnetic declination in degrees. Default: 0
Script Parameter: FFTRPOLE.DEC
Amplitude correction inclination
Amplitude correction inclination in degrees. Default: 20 (Northern Hemisphere) or –20 (Southern Hemisphere).
Script Parameter: FFTRPOLE.ACINC
  • Reduction to the pole has an amplitude component and a phase component.
  • At equatorial latitudes, North–South features can become exaggerated due to strong amplitude corrections applied when the declination plus wavenumber direction equals π/2 (magnetic East–West wavenumber).
  • To reduce or eliminate this effect, apply a higher latitude for amplitude correction only. This under-corrects North–South amplitudes but prevents blow-up artifacts.
Key Behaviors:
  • An amplitude inclination of 90° applies only the phase component (no amplitude correction).
  • An amplitude inclination of 0° applies both phase and amplitude corrections across the full range.
  • Default amplitude inclination: 20° in the Northern Hemisphere; –20° in the Southern Hemisphere.
The filter also requires the azimuthal orientation of the sensor (θ) to perform the reduction. The tool assumes survey lines are relatively straight and calculates orientation using the first and last point of each line.
Reduction to Magnetic Pole Filter
Where:
I
Ia
Inclination for amplitude correction (never less than I)
Ia = 20 if I >0
Ia = -20 if I <0
If |Ia| is specified as less then |I|, it is set to I.
D
