Apparent Susceptibility Calculation Filter
Use the Apparent Susceptibility Calculation option to apply a Fast Fourier Transform (FFT) Apparent Susceptibility filter to a channel.
- 1D FFT > 1D Filtering
- Moving Platform Gravity > Filters > Apply Single FFT Filter
Apparent Susceptibility Calculation filter options
Geomagnetic inclination |
Geomagnetic inclination. Default = 0 Script Parameter: FFTSUSC.INC |
Geomagnetic declination |
Geomagnetic declination. Default = 0 Script Parameter: FFTSUSC.DEC |
Amplitude correction inclination |
Amplitude correction inclination. Default = 20 Script Parameter: FFTSUSC.ACINC |
Depth to sources (in ground units) |
Depth to sources in ground units. Default = 0 Script Parameter: FFTSUSC.DEPTH |
Low-pass cutoff (in ground units) |
Low-pass Butterworth cutoff. Default = 0 Script Parameter: FFTSUSC.LP |
Total geomagnetic field strength (nT) |
Total geomagnetic field strength in nT. Default = 55000 Script Parameter: FFTSUSC.STRENGTH |
A susceptibility filter is a compound filter that performs:
Reduction to the pole
Downward continuation to the source depth
Correction for the geometric effect of a vertical square-ended prism
Division by the total magnetic field to yield susceptibility
An optional Butterworth low-pass filter may also be applied to remove noise from the data.
The susceptibility filter calculates the apparent magnetic susceptibility of the magnetic sources using the following assumptions:
The magnetic field has had the IGRF removed.
There is no remnant magnetization.
All magnetic response is caused by a collection of vertical prisms of infinite depth extent.
The result is in SI units.
The validity of the results depends on how well the observed field conforms to these assumptions.
Apparent Susceptibility Filter Components
Where:
H(ω): Downward continuation to depth h
G(θ): Reduction to the pole
K(ω): Geometric factor of a vertical prism (dimensions: 2a×¥×¥)
α: Half cell size
ω: Wavenumber (radians/ground unit)
θ: Wavenumber direction (azimuth)
Parameters:
h: Depth in ground units, relative to observation level at which to calculate the susceptibility.
Ia: Pole reduction amplitude inclination. This is the inclination used to apply only the phase component in the reduction to the pole. The default is
20. If |Ia | is specified to be less then |I |, it is set to I.
I: Geomagnetic inclination
D: Geomagnetic declination
F: Total geomagnetic field strength (nT)
