Vertical Derivative Filter
Use the Vertical Derivative option to apply a Fast Fourier Transform (FFT) vertical derivative filter to a channel.
Vertical Derivative filter options
Order of derivative
Specify the order of the derivative.
Default: 1
Script Parameter: FFTVDRV.ORDER
  • The vertical derivative is commonly applied to total magnetic field data to enhance shallow geological sources.
  • As with other filters that enhance high-wavenumber components of the spectrum, this filter can amplify noise.
  • To mitigate this, apply an additional low-pass filter to suppress high-wavenumber noise.
Parameter:
n: Order of differentiation
