Vertical Integration Filter
Use the Vertical Integration option to apply a Fast Fourier Transform (FFT) vertical integration filter to a channel.
- 1D FFT > 1D Filtering
- Moving Platform Gravity > Filters > Apply Single FFT Filter
Vertical Integration filter options
There are no user-defined parameters for this filter.
Calculates the vertical integral of the input transform.
This operation is the inverse of the vertical derivative.
The zero wavenumber is set to 0 to avoid undefined values.
Filter Formula
L(ω) = ω -1
