Expand Grid
Use the Grid and Image > Utilities > Expand Grid menu option (geogxnet.dll(Geosoft.GX.GridUtils.GridExpand;Run)*) to expand a grid by adding dummies to the new expanded region beyond the edges of the old grid. This is designed mainly to provide a bordering area to be filled by GRIDFILL in preparation for MAGMAP.
Expand Grid dialog options
Input Grid file name.(.grd file) Script Parameter: GRIDXPND.GRDIN |
Expanded output grid |
Output Expanded Grid file name.(.grd file) Script Parameter: GRIDXPND.GRDOUT |
Minimum % to expand the grid |
Minimum percentage to expand the grid.(Default = 10.0) Script Parameter: GRIDXPND.MINPER |
Shape of the output grid |
Shape of the output grid.(Can be 'SQUARE' or 'RECTANGLE'. default is 'SQUARE') Script Parameter: GRIDXPND.SHAPE |
Expand X dimension to |
Dimension in X direction which the input grid is expanded to. Script Parameter: GRIDXPND.XDIM |
Expand Y dimension to |
Dimension in Y direction which the input grid is expanded to. Script Parameter: GRIDXPND.YDIM |
GRIDXPND.XDIM and GRIDXPND.YDIM will default to input grid dimension values if they are not specified, or if they are set to 0.
The default dimensions are chosen to be compatible with the Wynograd FFT used by MAGMAP.
