Grid Data - Kriging
Gridding refers to the process of interpolating data onto an equally spaced “grid” of cells in a specified coordinate system. For an introduction to gridding and a summary of the different gridding methods click here.
Kriging
Kriging is a geostatistical gridding technique for random data, non-parallel line data, or orthogonal line data. Use the kriging method (KRIGRID) if the data is not sampled along lines that run roughly in the same direction, it is variable between sample locations, known to be statistical in nature, poorly sampled, or clustered. The method is ideally suited to geochemical or other geological sample-based data; it is rarely used with geophysical data, which tends to follow a natural smooth surface.
The Kriging algorithm determines the most probable value at each grid node based on a statistical analysis of the entire data set. For an overview of the method click here.
To perform kriging, you must supply a data channel, an output grid name and optionally the grid cell size. In addition, you also have a variety of options, including the ability to:
  • estimate the average error of the data at each grid node (nugget) and save it to an error grid file.
  • define the grid coverage (spatial limits of the area to be gridded).
  • grid the original data or its logarithmic representation (using cutoffs or a data range).
  • specify desampling values (for low-pass filtering) and a blanking distance (for removing values beyond a certain distance).
  • apply trend removal.
  • choose from multiple variogram models (power, spherical, Gaussian, or exponential).
  • specify the level at which the variogram becomes uncorrelated (sill) and the distance (range) at which the variogram model meets the sill.
Kriging outputs consist of a grid, an error grid and a kriging report (krigrid.log) file. The error grid contains the standard deviation of the estimation at each grid node. The report gives details about the input data, the parameters that were used for processing, and the calculated and model variogram and grid parameters. See Application Notes below for more details.
Use the Grid Data option from the Grid and Image > Gridding menu to grid geostatistical data using the kriging algorithm.
ClosedExpand to view other menus where this option is available:
Radiometric Processing:
  • RPS > Plotting > Grid Data
UXO-Marine:
  • UXO-Marine Sonar Utilities > Grid Data
Kriging – Gridding Options
Data to grid
Select the database channel to grid. To specify an array element, append to the channel array name the element index in square brackets. For example, Chan[1] would indicate the second element of the array channel "Chan".
Script Parameter: KRIGRID.CHAN
Output grid
Provide the name of the output grid file. This field is auto populated based on the active database and the selected channel to grid; however, you can override the default.
The default output grid format is selected automatically as the output file type. The type can be controlled using the browse dialog, which is accessible from the [...] button.
 Script Parameter: KRIGRID.GRID
Gridding method
The current gridding method is displayed.
Script Parameter: GRIDDING_TOOL.METHOD [Kriging = "2"]
Cell size
Specify a cell size for the output grid. This field is auto-populated with the calculated default grid cell size and rounded to the nearest ten or hundred:
Script Parameter: KRIGRID.CS
Error grid file
If a file name is provided, the error grid is saved under this name. The error at each grid node is an indication of the degree of confidence – this grid will contain the standard deviation of the kriging process at each grid node.
  • The resulting output grid will be within 2 standard deviations of the actual value 95% of the time, provided that the selected variogram model is correct.
  • Script Parameter: KRIGRID.ERR
    Extents and Data
    Spatial Extents
    Grid extents
    (X min, Y min,
    X max, Y max)
    Define the spatial limits of the area to be gridded. By default, these fields are set to the full extents of the current X & Y channels of the active database in order to include all the data in the database:
    X min, Y min: the ground coordinates of the first grid point at the bottom left corner of the rectangular grid area (by default, the minimum limits of the input data file are used).
    X max, Y max: the ground coordinates of the last grid point at the top right corner of the rectangular grid area (by default, the maximum limits of the input data file are used).
    To grid a subset of the data, enter the limits of the bounding rectangle, or press the Draw Extents button to interactively define the boundary extents – the output grid coverage will extend to these limits.
    Script Parameter: KRIGRID.XY
    [Draw Extents]
    Press this button to interactively define the grid boundary extents: in the Grid Preview pane, use the mouse to click & drag to draw a box, then release the mouse cursor to accept the final size of the box. The X & Y values will be updated in the Grid extents fields, and the preview window will be refreshed to show the newly defined extents.
  • You can draw the box in any of the four possible ways (e.g., from bottom left to top right).
  • [Reset Extents]
    Press this button to reset the grid extents to the initial state of defaults for the active database.
    The Grid Preview (with Auto-refresh enabled) and Variogram panes will be updated to reflect the change; however, the zoomed state (in/out) of the grid preview will not be affected.
    Blanking distance
    Specify the blanking distance: grid cells farther than this value from a valid point will be set to dummies in the output grid. Preferably, this parameter should be set to just greater than the maximum distance through which interpolation is desired. Normally, the blanking distance and the grid cell size should be set in conjunction.
    This field is auto-populated with the calculated default value as per following formula:
    Script Parameter: KRIGRID.BKD
    Cells to extend beyond data
    This is the number of grid cells to extend beyond the outside limits of the data. If the default is preserved (set to zero), the grid extents are limited to just overlapping the most extreme data value locations in X and Y.
    Set this to a number greater than zero to allow the grid to be extrapolated beyond the data edges. The actual extrapolation distance is limited by the Blanking distance value, and cells extended beyond this distance will remain dummies in the output grid.
    Do not use this parameter in place of the blanking distance in order to fill interior regions of the grid, as results are generally poorer than using the blanking distance. This is because the blanking distance measures the true radial distance between a given location and the nearest data point, while the "cells to extend" is measured only in X or in Y. The blanking distance is a true distance and the "cells to extend" is the number of cells, so you must multiply by the actual cell size to compare the two.
    Script Parameter: KRIGRID.EDGCLP (Default: 0)
    Data Filtering
    Mask channel
    Select a channel from the drop-down list to act as a mask.
    Only database channels that have the class property set as "MASK" are listed. Additionally, string channels and channels with array size greater than 1 are omitted from the list.
    The data values in the selected Data to grid channel with corresponding dummy (*) values in the Mask channel will not be used in the gridding process.
    The X & Y values will be updated in the Grid extents fields to reflect the masked data, and the generated masked grid (with the correct extents) will be automatically rendered in the Grid Preview window (the Auto-refresh option must be selected).
    Script Parameter: KRIGRID.MASK_CHANNEL
    Log option
    Choose whether to grid the original data or its logarithmic (base 10) form. Gridding in log space can help reduce distortion in highly skewed data, such as geochemical measurements.
    Available options:
    • linear: Grid the data as-is.
    • log, save as linear: Grid the base-10 log of the data (in logarithmic space). Any values below Log minimum are clipped at that threshold. The resulting grid is converted back to linear space before being saved to a grid file.
    • log-linear, save as linear:
      • Values above the positive Log minimum and below the negative Log minimum are gridded in logarithmic space.
      • Negative values are temporarily sign-flipped to compute logs, then flipped back.
      • Values outside the ± Log minimum range are converted back to linear space post-gridding and scaled to ensure boundary continuity.
      • Values within the ± Log minimum range remain intact and are gridded linearly.
      • Finally, the linear representation of the data (in both ranges) is saved to the grid file.
    • log, save as log: Same as log, save as linear, but grid values are kept in log space - the gridded data is saved to the grid file in its logarithmic representation.
    • log-linear, save as log: Same as log-linear, save as linear, but the grid values are not converted back from log space. The output grid remains in logarithmic space with large amplitude anomalies being somewhat moderated.
    See the Application Notes below for more details.
    Script Parameter: KRIGRID.LOGOPT
      linear: 0
      log, save as linear: -1
      log-linear, save as linear: -2
      log, save as log: 1
      log-linear, save as log: 2
    Log minimum value
    When gridding in logarithmic space (see Log option above), this parameter sets the minimum threshold value. The default is 1.
    Script Parameter: KRIGRID.LOGMIN
    Interpolation
    Kriging Filtering
    Low-pass desampling factor
    Specify the desampling factor as a number of grid cells. This effectively acts as a low-pass (smoothing) filter by averaging all points into the nearest cell defined by this factor.
    Leaving the default value (1) results in no pre-filtering other than de-aliasing by averaging data points within a cell.
  • See the Application Notes below for more details.
  • Script Parameter: KRIGRID.DSF
    Remove trend
    If the data manifests a trend, you can remove it from the data prior to gridding.
    Script Parameter: KRIGRID.RT [Do not remove trend: "no" (Default), Remove trend: "yes"]
    Variogram
    Model
    Select the variogram model to be used – the technique of kriging will use the model you select to estimate the data values at the nodes of the grid:
    • power
    • spherical
    • Gaussian
    • exponential
    In geochemical applications, the spherical and Gaussian models are typically most effective. The spherical model is mathematically simpler and it is recommended as a starting point.
    For a detailed description of the variogram models click here.
    Script Parameter: KRIGRID.MODEL.
    Range/Slope
    For spherical, Gaussian and exponential models, the range is the distance at which the variogram model reaches the sill value. Beyond the range, the data is uncorrelated.
    If no value is entered, it will be calculated by default.
    Script Parameter: KRIGRID.RS
    Power
    This is the power value for the power model. The default is 1.
    The nugget and slope (the rate of climb)  are calculated from the data based on a fitting algorithm for each model: the coefficient of the power term (i.e. slope for a linear model) is calculated by fitting a straight line to the observed variogram. The nugget will be 0, and the variogram data is inversely weighted as a function of h.
  • Using this procedure, the power model will best fit the start of the variogram. The interpolation will not be very good at distances beyond where the observed variogram deviates from the line defined by the model.
  • Script Parameter: KRIGRID.POWER
    Sill
    This is the value corresponding to the point at which the variogram becomes uncorrelated. Beyond the sill point, the variogram reaches its plateau point (or goes flat).
    If no value is entered (spherical, Gaussian and exponential models), the intelligent default will be displayed and used.
    Script Parameter: KRIGRID.SILL
    Nugget
    This is the average error in each data point, and it is indicated by the intersection of the variogram model with the h=0 axis. The default is 0 (indicating that there are no repeated samples).
    Script Parameter: KRIGRID.NUG
    [Update]
    The Update button becomes enabled when any of the Variogram parameters are modified.
    Press this button to recalculate the variogram (Variogram pane) and to regenerate the grid image (Grid Preview pane with Auto-refresh enabled) based on the adjusted Variogram parameters.
    Input variogram file
    If specified, this user-defined variogram file will be used as the variogram model and to populate the variogram model and parameters. If the field is left blank, the variogram is calculated according to the variogram model and parameters provided.
  • Only variogram files created by the Oasis montaj gridding programs are accepted. See the Application Notes below for more details on the variogram file format.
  • Script Parameter: KRIGRID.INVAR
    Output variogram file
    Specify the name of the output file that will contain the calculated variogram. The default name is auto-generated based on the active database and the selected channel to grid.
    This parameter is not available when the Run in background option is selected. In this case, the name of the output variogram file is constructed by appending ".var" to the provided Output grid name.
    Script Parameter: KRIGRID.OUTVAR
    Anisotropy
    Strike
    You can create a grid enhanced in a preferred direction using the strike direction and a weighting factor. This method enables you to incorporate the dominant geologic strike and define a preferential weighting in the strike direction, enhancing geological trends in your dataset.
    Enter the preferred strike direction angle measured in degrees clockwise (0°-360°) from the Y axis. This parameter is used in conjunction with the strike weight parameter (below).
  • The variogram is calculated by taking into account the bias implied by the weighting along strike and dip.
  • Script Parameter: KRIGRID.STRIKE
    Strike weight
    For anisotropic gridding, enter the weighting to be applied to data in the strike direction. The strike weight is the ratio of the semi-major and semi-minor axes of the weighting ellipse, with its major axis oriented in the strike direction. By default, this value is 1 and the medium is presumed to be isotropic.
    Script Parameter: KRIGRID.STRIKEWT
    [Restore Defaults]
    This button remains disabled until any of the fields default values are changed. Press the button to reset the gridding parameters to the initial state of defaults for the active database.
    When Restore Defaults is clicked:
    The following parameters are reset to their default values:
    • The cell size value
    • All the parameters on both the Extents and Data and Interpolation tabs
    • Only the parameters for the current gridding method are affected.
    The following parameters are not reset:
    • The data to grid selection
    • The output grid file name
    • The gridding method
    The Grid Preview (with Auto-refresh enabled) and Variogram panes will be updated to reflect any parameters changes; however, the zoomed state (in/out) of the grid preview will not be affected.
    [Run in background]
    Gridding can be a resource-intensive task. The duration can range from minutes to hours, depending on the size of the dataset. By choosing the Run in background option, you can execute the gridding process asynchronously, allowing you to continue using Oasis montaj for other tasks while the gridding is underway. Multiple instances of the gridding process can run concurrently in the background, whether they are for the same database or different ones.
    When you press the OK button with the Run in background option checked:
    An Oasis montaj command-line window (OMS) will open and run in the background on the taskbar until the gridding task is complete. Oasis montaj becomes available immediately after the OMS console window is launched. Do not close the console window before the process finishes — this will cancel the gridding, and no output grid file(s) will be produced. When the gridding process is complete, the console window will close automatically.
    In the current Oasis montaj project, in the Project Explorer:
    • You can monitor the progress of your gridding while working on other tasks.
      The progress of the gridding is monitored, and the status (e.g., processing, completed, failed, cancelled) is visually indicated in the Jobs tab. A new node is appended to the tab, and entries for each of the output files are created under this node in the tree.
    • As the gridding process for the selected database channel completes, the output grid is automatically added to the Grids node in the Data tab.
      You can double-click on the job node in the Jobs tab to initiate a re-run of the gridding using the previously set parameters. You also have the option to adjust these parameters before starting the process again.
    Closing the project (or the Oasis montaj instance) while background gridding is in progress will display a confirmation prompt. If you choose to close the project while the oms.exe is running in the background, the process will continue to execute to completion.
    The selection state of the Run in background option is retained on subsequent runs of the gridding tool in the same project.
    When running krigging in the background, a unique, time-stamped log file is created and added to the project folder.
    Once a gridding task is executed, the gridding options are retained when switching between different databases. The Grid Data tool will recall the previous gridding parameters associated with the current database, regardless of whether gridding tasks have been performed on different databases since.
    The kriging gridding creates a control file in your project folder. This file ("_krigrid.con") is then used by the gridding process. You can also build a KRIGRID control file through a text editor and take advantage of further specialized settings not available through the Grid Data. To learn more, go to topic Kriging from a Control File.
    Log Options
    If the data range is very wide and spans over several orders of magnitude, gridding in normal space may not honour the data distribution of interest, and the real patterns present in the data may get obscured in the process of gridding. If, however, the data is gridded in logarithmic space these very patterns will be revealed. Often it is more appropriate to grid geochemical data in logarithmic scale, as the element distribution changes in concentration by orders of magnitude over a short distance. Furthermore, depending on the data concentration and scatter, in order to maintain a consistent texture, it may be more appropriate to display the extremes of the data distribution in logarithmic space while the median range remains in linear space. This would be an appropriate approach with bimodal data.
    The log-linear options are not appropriate for geochemical data; they are intended for levelled geophysical data (e.g., sometimes the span of magnetic data is quite broad and in order to be able to observe the definition around the mean of the data distribution as well as at the extremes, this option is used). Prior to gridding the data for the two log-linear options, the data is altered as follows:
    if ( Z > Log_minimum))  Z = (log10( Z / Log_minimum) + 1.0) * Log_minimum);
    if ( 0 < Z ≤ Log_minimum))  Z is untouched
    if ( -Log_minimum ≤ Z ≤ 0))  Z = -Z
    if ( Z < -Log_minimum))  Z = -(log10( -Z / Log_minimum) + 1.0) * Log_minimum);
    This has the effect of treating large positive or negative values like logarithms, but gives a linear transform for values around zero.
    Log minimum value: when gridding in log space, this setting specifies the minimum cut-off in linear space. If one of the log, save as options has been selected, all values below this cut-off are replaced by Log_minimum. If one of the log-linear,save as options has been selected, this entry represents the two boundaries where the switch between linear and logarithmic gridding occurs.
    The illustration below intends to convey the variation between the various log options.
    Low-pass Desampling Factor
    The desampling factor is defined as a function of the grid cell size. Prior to further calculations, all points within each cell (of dimensions cell_size × desampling_factor) are averaged into a single value, which is then assigned to the centre of the cell.
    Default Desampling Behaviour
    The default desampling factor depends on the total number of contributing points:
    • If the total number of points is ≤ 100,000:
      The desampling factor is set to 1, meaning no desampling is performed.
    • If the total number of points is > 100,000:
      The desampling factor is calculated as the square root of the ratio of the total number of points to 100,000:
      where the result is rounded up to the nearest whole number.
    Effects of Desampling:
    • Low-pass filtering: Increasing the desampling factor produces a smoother output grid.
    • Performance optimization: It reduces computation time for variogram calculations when the input database is very large.
    If the database contains fewer than 100,000 contributing points, the desampling factor remains at 1. In this case, the only pre-filtering applied is de-aliasing at the cell level.
    The variogram calculation time is proportional to the square of the number of contributing points. Increasing this factor significantly reduces computation time while having minimal impact on the resulting variogram curve.
    The Variogram File Format
    The kriging method (KRIGRID) will write out the variogram of the data in the (*.var) file specified.
    The file is a standard Geosoft data file (ASCII text) that begins with comment lines containing information about the variogram model, in this case a spherical model . The model parameters are listed (model, nugget, sill, and range), together with SIGMA, which is the RMS difference between the variogram model and the observed variogram. The data columns contain the distance between samples (VH), the observed variogram (VG), the modelled variogram (VM), the number of points averaged to calculate the variogram (NP), and an index (I).
    Anisotropic Gridding
    In many, if not most, geologic situations, there is a natural bias (anisotropy) of the features of interest in the direction of geologic strike. You can create a grid enhanced in a preferred direction using the strike direction and a weighting factor. This method enables you to incorporate the dominant geologic strike and define a preferential weighting in the strike direction, enhancing geological trends in your dataset. This effectively creates an "ellipse" with the major axis in the direction of strike, and the minor-axis perpendicular to the strike.
    The Strike weight (>0.0) is the elliptical weighting (or preference) to apply along strike. The default value of 1.0 creates NO directional bias in the data. Typically, if your data is biased along strike, set the weighting to 2.0. This doubles the importance of data along strike. You can adjust the weighting to achieve a desired outcome by looking at results and experimenting a bit.
    A second and related use of these parameters is to correct for anisotropy in the observed sampling pattern. Statistical kriging works best when data is nominally evenly distributed. If you have data collected on lines at a high sample density relative to line separation, you should set the strike direction to be perpendicular to the lines, set the strike weight to be the line separation divided by the along-line sample interval.
    The Krigrid Log Report File
    Kriging produces a log report of the gridding process. The report gives details about the input data and lists the Kriging parameters. The GX lists the calculated and model variogram, performs the kriging and reports each grid row as it is completed; and finally writes out the output grid and reports the grid parameters.
