Grid Outline
Use the Grid and Image > Utilities > Grid Outline menu option (GX: GRID2PLY) to detect edge points in a grid image. You can either save the detected edges to a polygon file or draw them directly on the current map.
Grid Outline dialog options
Grid file
The name of the grid file from which to extract edge points.
Script Parameter: GRID2PLY.GRID
Action
Choose how to output the detected edge:
  • Draw on current map — draws the polygon on the active map.
  • Save to a file — saves the edge coordinates to a polygon (.ply) file.
The next dialog depends on which action you select.
Script Parameter: GRID2PLY.ACTION
(If the first letter is "D", the polygon is drawn to the current map.)
Minimum polygon size (points)
Specifies the minimum number of points a polygon must have to be included.
  • Default: 0 points (includes all polygons).
    This option is useful for very large grids with many small “island” polygons, as it ignores polygons with fewer than x points.
Script Parameter: GRID2PLY.MINPOINTS
Save Edges to a Polygon File
Polygon file name (.ply)
The name of the polygon (.ply) file to create or update.
Script Parameter: GRID2PLY.PLY
Save mode
Choose how to save the polygon data:
  • New file — create a new polygon file.
  • Append — add the polygons to an existing file.
Script Parameter: GRID2PLY.MODE
Edge resolution (cells)
Controls thinning of edge points.
  • Default: 1 cell (no thinning).
  • Values > 1 thin the edge to produce a coarser polygon.
Script Parameter: GRID2PLY.EDGERES (Default 1.0)
Draw Grid Edge on the Map
Line colour
Select the line colour for the edge.
Script Parameter: GRID2PLY.LCOLOR
Fill colour
Select the fill colour for the polygon.
Script Parameter: GRID2PLY.FCOLOR
Line thickness (mm)
Specify the thickness of the drawn edge line in millimetres.
Script Parameter: GRID2PLY.THICK
Line style
Choose a line style from the list.
Script Parameter: GRID2PLY.STYLE
Style pitch (mm)
Specify the style pitch for patterned line styles.
Script Parameter: GRID2PLY.PITCH
Enter the edge-thinning resolution for map output, in millimetres.
  • Default: 0.2 mm
  • Set to a negative value to disable thinning.
This option reduces rendering size for complex edges at large scales.
Script Parameter: GRID2PLY.EDGERESMAP (Default 0.2)
Only the outer boundary of the first non-dummy grid region is outlined.
Holes and interior islands are not detected.
If the grid outline is saved to a polygon file, it may be used for:
  • Masking operations
  • Drawing on maps using POLYDRAW GX
  • Use by external programs
The Edge resolution parameter controls thinning by removing colinear points below the specified resolution, producing a coarser edge.
  • For map output, thinning is disabled when the value is less than 0.0.
  • For file output, thinning is applied only if the resolution is greater than the grid’s X cell size.
