GDB to Voxel
Use the Voxel > Conversions > GDB to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportGDBToVox;Run)*), to import a channel from the current Geosoft database to a Geosoft voxel.
GDB to Voxel dialog options
Data channel
Select the database channel holding the data values to be imported to a voxel.
Script Parameter: IMPORTGDBTOVOX.DATA_CHANNEL
Output voxel
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel).
Script Parameter: IMPORTGDBTOVOX.OUTPUT_FILE
If a 3D Viewer is open during the import, then the output voxel will be displayed in the 3D Viewer window. Otherwise, the output voxel will be displayed into a new Voxel Viewer window. If the output voxel does not display, open the Advanced Settings dialog (Project > Settings >  Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
The import does not do gridding. The data must already be in a rectangular grid form. The import does support non-uniform cell sizes as long as all the cell sizes can be determined. The voxel created will have the same projection as the X, Y, Z channels and be of the same data type as the Data channel.
Non-Uniform cell sizes are handled on per axis (X, Y, Z).
The example fragment below defines a non-uniform voxel with the X axis having four different cell sizes:
 X   Y       Z   Data
 0   100  4   33.0
 15 100  4   34.5
 22 100  4   36.3
 26 100  4   37.02
 30 100  4   5.2
 40 100  4   523
The resulting X axis would be defined as:
 Min  Point   Max   Cell
 -10    0         10       20
  10    15       20      10
 20     22       24      4
 24     26       28      4
 28     30      32       4
 32     40      48       8
Note that if the points do not produce a finite non-uniform cell array for any axis, the import will fail.
Use the gridding tool to produce voxels from random data points.
