Import ASEG-ESF
Use the Database > Import > ASEG-ESF menu option (geogxnet.dll(Geosoft.GX.Database.ImportAsegEsf;Run)*) to import ASEG-ESF data into the current or a new database.
Import ASEG-ESF dialog options
ASEG-ESF file
Specify the name of the ASEG-ESF file to import. This file contains a header defining the data type and a body. The header defines the mandatory fields. Each row of the body represents a specific sample, and each column represents a particular data field for that sample.
Script Parameter: ASEGESF.FILE
Output database
Specify the Output database name. It defaults to the same name as the input ASEG-ESF file.
Script Parameter: ASEGESF.DATABASE
The ASEG-ESF format intends to cover all Electrical methods data formats. It is an ASCII fixed field flat file that contains a header and a body. The header fully describes the type of survey.
You can download the ASEG-ESF file format standard from the ASEG Technical Standards page on the aseg.org.au website.
  • With the licensed version of Oasis montaj, the import adheres to the format in the above document. If you would like to import IP data that does not follow the format, yet still identify it as an IP database, import it using the ASCII Import, clearly identifying the array data. Then, use the "IP / Process / Setup database for IP" to validate, if all the mandatory IP channels are in the database.
