Edit MAPPLOT Template
Use the Edit MAPPLOT Template dialog to modify a map template based on existing default formats. The dialog opens from the MAPPLOT Template Manager.
Edit MAPPLOT Template dialog options
Template name |
The name of the template you want to edit is displayed. |
Map style |
Select either a Full Map (select Map) or Figure (select Figure) style map. The Full Map style is normally used for A1/A0 size maps, and the Figure style map for A3/A4. |
Media size |
Select from a variety of metric (A4, etc.) and imperial standards (letter, etc.) |
Layout |
Select one of the two options:
Fixed or minimum size |
Select the size on the page: |
Map margins (cm) |
Specify the margin width in cm for bottom, right, top, and left margins. |
Inside data margin |
Enter the margin width between the data and the map surround in cm. |
Positive plot direction |
Specify the direction in which x is positive (left or right). |
Vertical reference angle |
Enter the angle (in degrees, counterclockwise) at which a line is considered vertical. Any line within this angle is considered vertical. Default is 67.5. |
This GX runs only in interactive mode.
The system provides a variety of default templates that enable you to create your own standard maps with logos, custom layouts and other elements as required. For example, you may use the default A4 or A3 templates to create your own layout that you use regularly for map making.
Map templates are currently saved permanently in your system so when you are learning the system, we suggest you experiment using the same template until you are ready to create a final version with a custom name. You may want to create a test template, called TEST, for example.
Full map and figure style layouts:
