Split on Fiducial
Use the Split on Fiducial option, (geogxnet.dll(Geosoft.GX.Database.SplitLineAtFid;Run)*), from the Database Tools > Line Tools, to split a line into two lines at a specified fiducial.
The option is also available in the Moving Platform Gravity > Split Line menu.
Split on Fiducial dialog options
Line to split
Input line name, will be shortened up to Fid.
Script Parameter: SPLTLINE.IN
New line
Output line name, will get from FID and higher.
Script Parameter: SPLTLINE.OUT
Split at fiducial
Fiducial at which to split the line.
Script Parameter: SPLTLINE.FID
Reset fiducial start values to zero
After splitting the line, the fiducial of the first point can be preserved (default) or set to zero .
Script Parameter: SPLTLINE. RESET_FID_STARTS[0-No, 1-Yes]
It is often useful to split an existing line into parts. For example, an entire survey flight may be imported as a single line, then sub-divided into separate survey lines by displaying the survey trace and using the Split on Fiducial GX.
