Plot Symbols (SYMBOLS GX)
The most basic type of symbol plotting in Oasis montaj is to draw symbols on a map at all data points along all selected lines in a database.
Use the Location Plot option (SYMBOLS GX) from the Map Tools > Symbols menu to quickly plot symbols. Specify the following:
- Symbol
- Size (mm)
- Weight
- Line colour
- Fill colour
- Grouping
The option is also available under Euler 3D > Plot Solution Symbols.
Location Plot dialog options
Plotted data is masked to the current data view’s clip region. Data outside the clip region is still written to the map, but is not visible. To see this data, uncheck the "Masked to view" box in the Map Manager tool.
If you are plotting symbols to a data view that is not oriented in 3D, the current X, Y channels must be set in the database.
If you are plotting symbols to a 3D oriented view, the current X, Y and Z channels must be set in the database. Symbols plotted to a 3D oriented view are projected to the section plane irrespective of the section thickness.
