Move Takeoff Locations
Use the Move Takeoff Locations option (geogxnet.dll(Geosoft.GX.UAVSurvey.MoveTakeoffLocation;Run)*) from the UAV Merge Sorties > Plan Survey menu to relocate the takeoff locations.
Move Takeoff Locations dialog options
Survey name
Select the survey you would like to work with from the list of available project surveys. Multiple surveys can be created within the same GPF.
Script Parameter: PLAN_UAV_SURVEY.SURVEY_NAME
Select subarea
You can update a series of takeoff points within the same invocation of this tool; it runs in a loop. In order to do so effectively, select the map of the entire area of interest, and as you click on the Locate button to relocate the takeoff point of the next subarea, the map will automatically zoom on the selected subarea.
Subareas have unique names. From the drop-down list, select the one for which you wish to move the takeoff location. The takeoff location does not need to be inside the subarea. When selected outside the subareas, a white line joins it to the centre of the subarea it belongs to.
Script Parameter: PLAN_UAV_SURVEY.SELECTED_SUBAREA
Plan map
Specify the plan map on which to select the new takeoff location. The map is zoomed on to the selected subarea.
Script Parameter: PLAN_UAV_SURVEY. OUTPUT_MAP
Access point CSV file
If you have a CSV file with the location of the access points provide it here. These points are plotted on the above map as black X symbols, to guide you in selecting the location of the new takeoff point.
Script Parameter:PLAN_UAV_SURVEY.ACCESS_POINT_FILE
Update line path and coverage
The option is disabled if the planned paths have not been yet calculated.
When enabled, check this box if you wish to recalculate the planned path so that it starts and ends at the new takeoff location
Script Parameter: PLAN_UAV_SURVEY.UPDATE_LINE_PATH [0 – Do not update, 1 – Update]
[Locate]
Click the button to relocate the takeoff point of the next subarea.
You may be running different scenarios to plan the same survey. Each scenario can be saved under a separate survey name in the same working folder. The files related to each survey are prepended by the survey name in order to avoid conflict.
It is recommended to select a map on which the takeoff locations and subarea polygons are displayed. Prior to selecting the new location (Left mouse click), you can use shortcut keys (P-Pan, Z- Zoom in, X- Zoom, L – Last view, F- Full map) to navigate on the map.
The confirmation is displayed on the selected map by moving the location symbol (Circle) to the new position.
*GX.NET tools are embedded in the geogxnet.dll file located in the \Geosoft\Desktop Applications\bin folder. To run this GX interactively (outside the menu), navigate to the bin directory and specify the GX.NET tool in the required format. See the topic for more guidance.
