Reproject a Voxel
Use the Voxel > Utilities > Reproject a Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ReprojectVoxel;Run)*), to reproject a voxel that includes a projected coordinate system.
Reproject a Voxel dialog options
Input Voxel
File name
Select the voxel file to be reprojected.
Script Parameter: VOXEL_REPROJECT.INPUT
  • The input voxel must have a projected coordinate system. Voxels that lack a coordinate system or with geographic coordinates can not be reprojected.
  • Coordinate system
    The Coordinate system entry is read-only and is automatically populated from the input voxel.
    Coordinate system units
    The Coordinate system units are read-only and are automatically populated from the input voxel.
    Output Voxel
    File name
    Specify the output voxel file name. A new voxel file will be created from the input voxel file, with a modified projected coordinate system. The extension ".geosoft_voxel is added automatically.
    Script Parameter: VOXEL_REPROJECT.OUTPUT
    Coordinate system
    The output Coordinate system is read-only and is automatically populated from the output voxel.
    To change the coordinate system, click the Modify Coordinate System button. The default is "Undefined"; however, once a coordinate system has been set, it will be remembered and populated on subsequent runs.
    Script Parameters:
    • VOXEL_REPROJECT.IPJ_NAME
    • VOXEL_REPROJECT.IPJ_DATUM
    • VOXEL_REPROJECT.IPJ_METHOD
    • VOXEL_REPROJECT.IPJ_LOCALDATUM
    The output Coordinate system units are read-only and are automatically populated from the output voxel.
    To change the coordinate system units, click the Modify Coordinate System button. The default is "metre"; however, once a coordinate system has been set, it will be remembered and populated on subsequent runs.
    The units apply to the horizontal and vertical coordinates of the voxel. When reprojecting a voxel into a coordinate system that uses different horizontal units, the vertical units are also scaled.
    Script Parameter: VOXEL_REPROJECT.IPJ_UNITS
    [Modify Coordinate System]
    Click the Modify Coordinate System button to display the Coordinate System dialog.
    The output voxel projection is restricted to projected coordinate systems.
    The Reproject a Voxel option creates a new voxel file from the input voxel file, with a modified projected coordinate system. The voxel cell sizes remain unchanged (except for scaling to account for a change in units) and the data is not re-sampled. The origin is altered in order that the output voxel is located at the same geographic location on the earth as the original however, the depth /vertical location of the voxel is not changed. The voxels rotation about the vertical axis is altered to ensure that the orientation with respect to north remains the same.
