Voxel to SEG-Y
Use the Voxel > Conversions > Voxel to SEG-Y menu option (geogxnet.dll(Geosoft.GX.ConvertVoxelToSegY;Run)*), to export a Geosoft Voxel to a 3D SEG-Y file.
Export Voxel to SEG-Y dialog options
Input voxel
Select the Geosoft Voxel file to be exported.
Script Parameter: CONVVOXTOSGY.INPUT_VOXEL
Output SEG-Y name
Specify the name of the 3D SEG-Y file to be created.
Script Parameter: CONVVOXTOSGY.OUTPUT_SEGY
Vertical sample interval
Specify the constant vertical sample interval to be used.
Script Parameter: CONVVOXTOSGY.SAMPLE_INTERVAL
  • The voxel to be exported must be a numeric Geosoft voxel.
  • The text header is exported in ASCII format.
  • Only voxels with constant cell sizes in X and Y can be exported.
  • Irregular cell sizes in Z will be re-sampled to a user-specified constant sample interval.
  • All voxel values will be converted to 4-byte IEEE floating point values.
  • Dummy values in the voxel will be converted to zero in the SEG-Y file.
  • If all cells in the voxel at an X, Y location (a vertical trace) are dummy, the entire zeroed trace will be marked as "dead" in the SEG-Y file.
  • Rotation about the Z-axis is supported, but rotations about the X- or Y-axes are not.
