Apply View Mask
Use the Map Tools > Masking > Apply View Mask option (VIEWCLIP GX) to set the clip area of a view using a polygon mask file.
Apply View Mask dialog options
After changing the view clip area, individual groups within the view can be clipped to the defined limits by enabling their clip attributes. To do this, select the group, right-click, and choose the Clipped option from the pop-up menu.
Polygon Mask Files
Polygon files are ASCII text files with the default
.plyextension. -
Each file contains a list of X,Y coordinates that define one or more polygons.
Files can include any number of polygons, each with any number of vertices.
The first and last points of each polygon are assumed to be connected.
File Structure Guidelines:
Each polygon begins with a line starting with
poly# (with P or p in column 1). -
Comment lines begin with / in column 1.
Creating Polygons Interactively
You can create clip polygon files interactively using the digitising tools available in the Map Tools menu.
Example: Single Polygon File
/ Sample single polygon file
poly 1
1376027.6061 6178025.9399
1382846.3129 6178025.9399
1382846.3129 6182748.8182
1376027.6061 6182748.8182
Example: Multiple Polygon File
(Note: The keyword exclusive following a polygon entry, such as poly 3, indicates exclusive regions or holes within a polygon set.)
/ Sample three polygon file
poly 1
1375594.6724 6181961.6718
1378706.3838 6181961.6718
1378706.3838 6184716.6842
1375594.6724 6184716.6842
poly 2
1375757.0225 6178629.4188
1379896.9516 6178629.4188
1379896.9516 6181174.5254
1375757.0225 6181174.5254
poly 3
exclusive
1380546.3523 6175926.8828
1384550.9896 6175926.8828
1384550.9896 6179022.992
1380546.3523 6179022.992
