Window X ,Y to Polygon Mask
Use the Database Tools > Window Data > Window X ,Y to Polygon Mask menu option (WINXY GX) to mask the X and Y channels to the area defined by a polygonal mask file. This restricts all subsequent map-based processing to data within the defined region.
Window X ,Y to Polygon Mask dialog options
Mask polygon file |
Specify the ASCII file defining polygon masks. Script Parameter: WINXY.MASK |
Dummy inside or outside |
Indicate whether you want to dummy inside or outside of the polygon mask area. Script Parameter: WINXY.DUMMY |
This GX is used to limit the X and Y coordinates to the part of the area to be plotted. All MAP based processes will use the X and Y channels as the plotting coordinates. By dummying those parts of the area outside the area of interest, all plotting will be restricted to the defined area.
A copy of the original X and Y channels is saved to __X and __Y (if these channels do not already exist). Future windowing operations will use these channels as the source channels. (If running interactively, a warning message is displayed asking whether you wish to overwrite the backup channels).
Polygon Mask Files
Polygon files are ASCII text files with the default
.plyextension. -
Each file contains a list of X,Y coordinates that define one or more polygons.
Files can include any number of polygons, each with any number of vertices.
The first and last points of each polygon are assumed to be connected.
File Structure Guidelines:
Each polygon begins with a line starting with
poly# (with P or p in column 1). -
Comment lines begin with / in column 1.
Creating Polygons Interactively
You can create clip polygon files interactively using the digitising tools available in the Map Tools menu.
Example of a single polygon file:
poly 1
1376027.6061 6178025.9399
1382846.3129 6178025.9399
1382846.3129 6182748.8182
1376027.6061 6182748.8182
Following is an example of a three polygon file:
/ / Sample three polygon file /---------------------------
poly 1
1375594.6724 6181961.6718
1378706.3838 6181961.6718
1378706.3838 6184716.6842
1375594.6724 6184716.6842
poly 2
1375757.0225 6178629.4188
1379896.9516 6178629.4188
1379896.9516 6181174.5254
1375757.0225 6181174.5254
poly 3
1380546.3523 6175926.8828
1384550.9896 6175926.8828
1384550.9896 6179022.992
1380546.3523 6179022.992
