Paste into Map
Use the Paste into Map dialog to paste a copied georeferenced group into a new map view.
Paste into Map dialog options
Centred in the display window |
Select this option to paste the group into a new view centered within the display window |
Select this option to paste the group at the same scale with a specified offset. This enables the X and Y offset fields. |
X offset (mm) |
Specify the horizontal offset in millimetres (map units). |
Y offset (mm) |
Specify the vertical offset in millimetres (map units). |
