Edit Channels
When multiple channels are selected, you can right‑click any selected channel header to open a context menu with options for managing and repositioning the selected channels. The Edit menu option lets you modify shared properties across multiple selected channels at once, including regular channels and array channels.
Open the Edit Channels Dialog
In the database, select two or more channels (Ctrl‑ or Shift‑select).
Right‑click any selected channel header.
Choose Edit from the context menu.
The Edit Channels dialog opens. A banner at the top indicates how many channels are selected and confirms that changes apply to all selected channels.
Edit Channels dialog options
Mixed Values When the selected channels do not share the same value for an attribute:
Leaving a field unchanged preserves each channel’s existing value. Entering a new value applies that value to all selected channels. |
Class |
Describes the type or purpose of the channel (for example, survey line, elevation, interpretation code).
Units |
Specifies the measurement units for channel values (for example, m, m/s, nT).
Protected |
Controls whether channels are protected from certain operations. When editing multiple channels, the Protected checkbox supports three states:
Display Settings Display settings control how channel values appear in the user interface. |
Format |
Controls how numeric values are displayed. Available formats include the standard options used elsewhere in the database.
Field width |
Specifies the display width (in characters) for channel values.
Decimals |
Specifies the number of decimal places displayed for numeric values.
Applying or Discarding Changes |
[OK] |
Click OK to apply your changes.
[Cancel] |
Click Cancel or close the dialog to discard all changes.
The Edit Channels dialog allows you to efficiently standardize metadata and display settings while preserving intentional differences between channels. The -different values- indicators and the indeterminate Protected state ensure that only the attributes you choose to change are applied across the selection.
How Multi‑Channel Editing Works
All changes apply to the selected channels.
Only the attributes you explicitly modify are updated.
Attributes you do not change remain unchanged for each channel.
Validation and Limitations
All fields are validated before changes are applied.
Invalid entries (for example, non‑numeric values for Field width or Decimals) are flagged and must be corrected.
Long text values may be truncated at internal limits without warning.
