Edit Channel
Select the header cell of the channel you want to modify. Right-click to open the context menu, and choose Edit. Use the Edit Channel dialog to adjust the channel's parameters.
Edit Channel dialog options
Name
The name of the channel. This appears in the channel header cell.
Label
An optional label for the channel. When plotting channel data, the label will be displayed instead of the channel name.
If you import a channel with an invalid name (e.g. "My 34 .. chan"), the software will generate a valid name (e.g. "My_34____chan") and store the original name in the channel label. This allows users to retain and display non-valid names when plotting.
Data type
The type of data in the channel.
This field is read-only and can only be set during data import.
Array Size
The size of the data array. For example, radiometric data may have arrays up to 256.
Class
The classification of the channel (e.g., ASSAY, MASK).
Units
The number of units in the channel.
Protected
Check this box to protect the channel. Uncheck to remove protection.
Display
Format
Choose the data format from the drop-down list:
  • Normal
  • Exponent
  • Time
  • Date
  • Geographic
  • SigDigit
  • Hexidecimal
Field width
Specify the field width for the channel.
Decimals
Specify the number of decimal places to display.
