Resolving Data Positioning in Oasis montaj
The second major step in the Oasis montaj data processing workflow is resolving data positioning. This involves interpolating, projecting, and/or warping data to align it accurately within a geographic context.
Introduction to Coordinate Systems and Projections
A coordinate system defines how geographic locations on Earth (e.g., longitude and latitude in a specific datum) are represented on a flat map. Geographic locations—whether expressed as X/Y or Lat/Long—are either in an implied or known coordinate system..
If no coordinate system is specified, Oasis montaj assumes the data is in an unknown system.
Why Define a Map Coordinate System?
Defining coordinate systems allows you to:
Annotate maps with longitude and latitude locations
Convert data or grid locations between coordinate systems
Display information on a map that is in a different coordinate system
Define a warped coordinate system to fit data to a desired map coordinate system
Attaching Coordinate System Information
In *.GI file. Once you have attached a coordinate system to a set of coordinates,
Automatically reproject data to match other datasets (of different coordinate systems)
Maintain dynamic links between maps and data, even across different coordinate systems
Use "smart projections" to project data "on the fly" during display
This enables maps to contain multiple views, each using different coordinate systems, while preserving data relationships.
Defining Projections
Map projections can be defined for:
In most cases, you only need to define the coordinate system for the X and Y channels of the original database. This definition is then:
Passed to grids during gridding
Inherited by map views when created and posted to the map
Coordinate systems for channels, grids, and views can be viewed or modified at any time. However, modifying map coordinate systems requires precise and accurate knowledge of the coordinate system parameters.
What do you want to do?
Define and Modify Map Projections
Define the Coordinate System for Database Channels
Define the Coordinate System of a Grid
Define the Coordinate System of a Map View
Annotate Longitude and Latitude Coordinates on a Map
Display with Different Coordinate Systems on a Map
Define and Apply a Warp
Define a Warp File Interactively
Define a Warp File Semi-interactively
