Extracts values from a raster elevation source to the collar feature class of a drillhole dataset. Creates a new field containing raster values for each collar location, or overwrites selected collar elevations (Z locations) with values from an elevation raster.
The Get Elevations tool supports two modes of use. You can use it to get elevations for:
| Parameter | Explanation | Data Type |
Get elevations for |
Choose the mode to use for getting elevation values. |
Select holes to replace elevations |
Selected drillholes will have their collar elevation values replaced by the values extracted from the raster dataset. |
New field name |
Specify a name for the field in which elevation (or raster) values will be saved. |
Elevation source type |
Select the elevation source type:
Elevation raster source |
Browse to select a raster dataset in a geodatabase to extract elevation values from. See Technical Notes below for more details. |
Raster dataset |
Confirm existing elevation |
Check this checkbox to confirm that you intended to replace the original elevations with new values from the elevation source.
The elevation source must be a raster dataset in a geodatabase. Use the Import Geosoft Grids tool if you have elevation data in Geosoft Grid file format, or use the Find Geoscience Data option to obtain free elevation data for the project area. Note that the Get Elevations tool can be used to extract values for any type of raster data (e.g. geophysical or geochemistry values) to the collar feature class, if desired.
