Template Files
Import templates (.i3, .ii3, i4, .ii4 files) contain all of the import parameters including data source type (Text, Access, Excel,ODBC etc), data source location, and the type of data (Collar, Survey, From-To, Point), so these values do not need to be specified again. These templates are useful to re-import data using the same settings, or to import new data with the same formatting.
Template files are automatically created and saved on your file system when any of the Drillhole import tools are run. If this is the first time importing drillhole data, it is unlikely you will have any template files. If you have previously imported drillhole data, either in Target for ArcGIS Pro or in another Geosoft software, there may be template files available for you to use.
Drillhole data can be imported in two ways, either with or without template files:
Related topics
