The Drillhole Settings options in the backstage area allow you to change various import related settings for drillhole datasets.
To open Drillhole Settings, follow these steps:
Settings button in the lower left corner of the page.Here you can change the conversion of negative values option, the desurveying method, the survey data dip direction, the desurvey resolution and the depth tick interval, to use when importing new drillhole data. For an existing drillhole dataset, you can change the desurveying method, the survey data dip direction, the desurvey resolution and the depth tick interval, and the changes will be applied to that dataset.
| Parameter | Explanation | Data Type |
Default Settings |
Convert negative values on import |
Determines if assay negative values are automatically converted on import.
Desurvey method |
Determines what mathematical process should be used to convert a series of measurements of dip and azimuth taken at depths down a borehole, into (X, Y, Z) coordinates.
Negative survey dips point |
This determines if the holes survey dips are negative downward or positive downward:
Resolution |
The import process calculates the hole location at a spacing determined by this interval.
Depth tick interval |
The spacing interval (in ground units) at which ticks are plotted, is determined by this parameter.
Change Settings for Existing Drillhole Datasets |
Desurvey method |
Resolution |
The resurveying process calculates the hole location at a spacing determined by this interval.
Assay values are measured geochemical concentrations of elemental abundance in a rock, or other geological samples (soil, water, drillcore, rock sample). When assay values are measured in the lab, sometimes the amount of an element present is very small, making it too little, or too low to be accurately detected by the method which is used to measure the concentration. This results in assay measurements that are reported using a "lower detection limit" value, which is often reported as a negative value (or using a less than '<' sign), such as "-0.01". On import, you can choose to automatically convert these negatives (or < signs) to a value 1/2 that of the numeric value used.
