Use this wizard dialog to specify the import fields and parameters for the import data file. Once all the required parameters and fields are specified and mapped, the message “Ready to import data” will display at the bottom of the dialog and the Finish button will be enabled.
| Parameter | Explanation | Data Type |
| Channel Type | ||
Not imported |
Select the Not Imported option if you do not want the selected (highlighted) channel in the bottom preview window to be imported. |
Data |
Select the Data option if you want the selected (highlighted) channel in the bottom preview window to be imported as Data. |
Line |
Select the Line option if you want the selected (highlighted) channel in the bottom preview window to be imported as Line data. |
Array |
Select the Array option if you want the selected (highlighted) channel in the bottom preview window to be imported as Array data. |
Size |
Specify the size of the Array channel (e.g. 256). |
| Parameters | ||
Field name |
Specify the field name. The default is the name from the "Data headings on row" from Drillhole Import Wizard - Step 1 of 3. |
Data Type |
Specify the data type. The "intelligent" default is determined from the "Channel Type".
Data Format *String Size |
Specify the data format. The "intelligent" default is determined from the "Channel Type" and the "Data Type".
Dummy |
Specify the alpha and /or numeric characters to be used as the dummy. The default is (*). |
Preview window |
Channel Parameters |
The columns in the import file are displayed in this window. Select (highlight) each channel to specify the "Channel Type" and "Parameters" for each. |
Finish> |
Click the Finish> button to import the data. |
Text Data - Drillhole Import Wizard:
