Modify Planned Drillholes
Summary
The Modify tab of the Drillhole Planning tool can be used to modify existing planned drillholes by repositioning the collar and target locations or by redefining the collar and trace parameters.
Usage
There are three modes that can be used to plan drillholes:
Specify the proposed collar and target locations. In this mode, the trace parameters will be calculated.
Specify the proposed collar location and trace parameters. In this mode, the target location will be calculated.
Specify the proposed target location and trace parameters. In this mode, the collar location will be calculated.
When using the collar and target planning mode, you can specify the locations by clicking directly on a map or scene, or by changing the XYZ values for the collar or target in the tool. In this mode, the trace parameters (hole length, azimuth and inclination) will be automatically calculated.
When using the collar and trace planning mode, you can specify the collar location by clicking directly on the map or scene or by changing the XYZ values for the collar in the tool. You can specify the trace parameters (hole length, azimuth and inclination) by entering the values in the tool. In this mode, the target location will be calculated.
When using the target and trace planning mode, you can specify the target location by clicking directly on the map or scene or by changing the XYZ values for the target in the tool. You can specify the trace parameters (hole length, azimuth and inclination) by entering the values in the tool. This mode allows you to define the target location and angle of approach and have the collar location calculated for you.
Saving the Drillhole
Pressing the Save button, after the drillhole parameters are correctly set, will run the resurveying tool and commit the current drillhole location and parameters to the drillhole dataset. You may also Cancel the modifications and revert back to the original drillhole parameters, or Delete the planned drillhole from the dataset.
Parameters
Technical Notes
Snap Collar Elevation to Topography
For either of the three drillhole planning modes described above, you can specify a topography (or elevation) raster dataset to use for the collar elevation values.
This option is required when using the Target and Trace planning mode.
When this option is enabled and a raster dataset is selected, the X and Y location of the collar point will be used to extract a Z (elevation) value from the specific raster dataset. Note that the selected raster dataset must be a raster in a geodatabase. Topography data can be imported from Geosoft grids files by using the Import Geosoft Grids tool that is part of Target.
Drillhole dip-direction convention
The assumed convention that is used in Target for ArcGIS Pro is that downward pointing holes have a negative dip value and upward pointing holes have a positive dip value. This convention can be changed in the Drillhole Settings tab of the backstage area. Planned drillholes follow the same convention: by default, they will have negative dips for holes pointing down. If the user has changed the setting to use the opposite, the planned drillholes will have positive dips pointing down.
Related Topics
