Drillhole Import Wizard - Filter Conditions (SQL Builder)
Summary
Use this dialog to specify conditions to enable you to filter out unwanted rows. When importing fields (columns) from an external database into the current geodatabase feature dataset, you may only want certain rows to be imported.
Usage / Condition Syntax
Wildcards (%) can be used with string fields. For example to select only Collar IDs that start with "AX" you would specify, "equals AX%".
When using the "between" filter condition you must specify your two numbers separated by a comma for example, "between 10,19".
Conditions applied to the same field should apply the logical OR. Conditions applied to different fields should apply the logical AND.
| Parameter | Explanation |
Field |
Select one or more field(s) for which you want to define a condition on which to filter. |
Condition |
Specify a condition type for the field(s). Your choices are:
Value |
Specify the value(s) against which to compare the field(s). |
Related Topics
Drillhole Import Wizard:
Import Drillholes from Excel or Access Files
Import Drillholes from an ODBC Connection
