Create Feature Class
Summary
The Create tab of the Geologic Interpretations tool is a trimmed-down version of the existing tool "Create Feature Class" that will allow you to create new feature classes to store and organize drawings (interpretations) created on section views. You can then easily share the subsurface geology interpretations with your colleagues.
Usage
Use the Create tab to create a new Geologic Interpretations Feature Class in the current drillhole dataset. For each feature class, you will be able to specify which 'rock types' (attributes) you want to draw and assign a color to be used with each of them. When drawings/interpretations are done later on, you can choose which of these attributes to use in order to draw different rock types – the drawings will immediately appear with the correct colors.
The feature class created is added as a layer to the current scene/map and as a Geologic Interpretations Feature Class to the following panes:
- Drillhole Datasets > Datasets
- Drillhole Datasets > Add Data
- Symbology > Set Defaults
Depending on what you want to draw, you will need to define the feature class to be of one of the following types:
- Polyline – if you want to create open/flat surfaces (contacts, faults, or other linear features).
- Multipatch – if you want to create closed 3D geological bodies (rock type units)
Several features to draw (interpretations) can be stored in one feature class, but all of them have to be of one type (either multipatch or polyline).
Interpretations / Feature Class Considerations:
- The drawings created will be stored with the feature class that resides inside the existing current drillhole dataset.
- There will be one feature class per type of drawing - multipatch, line, point.
- The feature class shares the coordinate reference system of the drillhole dataset.
Parameters
Technical Notes
It is not possible to set the coordinate system for the drawings/interpretations to be different then the drillholes. The Interpretations Feature Classes must share the same coordinate system as the drillhole dataset - this is required since all feature classes inside a dataset must have the same coordinate system inherited from the feature dataset.
The feature class itself does not contain the attributes/features until it has a spatial object stored in it.
Related Topics
