Current Drillhole Dataset Selector
Summary
The Drillhole Dataset selector is found on the Target ribbon, within the Current Dataset group.
Usage
When working in a project with more than one drillhole dataset imported, use the Current Drillhole Dataset selector to choose which of the open drillhole datasets is the currently active dataset.
Multiple drillhole datasets can occur if you have:
  • More than one dataset imported via the Drillhole Data import tools
  • Another geodatabase opened, and which contains a drillhole dataset
If there is only one drillhole dataset present, the Current Drillhole Dataset selector will appear disabled (grayed out):
If there are multiple drillhole datasets, expand the dropdown list to select one of the drillhole datasets available in the project. The Current Drillhole Dataset will load under:
  • The Add Data tab of the Drillhole Datasets pane
  • The Manage and Set Defaults tabs of the Drillhole Symbology pane
  • The Create, Modify and Manage tabs of the Section Tool pane
The Datasets tab of the Drillhole Datasets pane will always show all drillhole datasets in the current project (.aprx ).
Related Topics
