Add To Map
There are several different tools for searching and adding geoscientific data to maps and scenes in Target for ArcGIS Pro. You can browse the topics in the Add To Map section, or you can use the list below to go directly to the topic you need:
The Geoscience Data Service is a web portal that allows you to connect to the Geosoft Public DAP Server to search for, and download global geoscience datasets by keyword or location.
Add Drillhole Data feature classes or attributes to the active map or scene, as layers. The drillhole data added will be automatically symbolized with convenient defaults.
The Datasets tab of the Drillhole pane allows you to view the drillhole dataset(s) in the current project in a simplified view (compared to the Catalog view).
If you don't see what you're looking for here, try typing your question in the Search box at the top of this page.
