Point Data - Drillhole Import Wizard
Summary
Use this tab to specify the import parameters for the Point (depth) data to be imported into the current geodatabase feature dataset. Once all the required fields are specified and mapped, the message “Ready to import <Point View> data” will display at the bottom of the tab and the OK button will be enabled.
Drillhole Import Wizard - Point Tab
Parameter Explanation
Point View
The name of the selected Point (depth) data. This field is read-only.
Additional sub-tabs are created for each selected Point (depth) data to be imported.
Database Fields
The database fields that are available for import. Select (highlight) a field to specify the Channel Type and parameters.
Filter Conditions
Click this button to open the Filter Conditions dialog.
Channel Type
Not imported
Select the Not imported option if you do not want the selected (highlighted) database field to be imported.
Data
Select the Data option if you want the selected (highlighted) database field to be imported as data.
Hole ID
Select the Hole ID option if you want the selected (highlighted) database field to be imported as Hole IDs. This is a required field.
Depth
Select the Depth option if you want the selected (highlighted) database field to be imported as "depth" data. This is a required field.
Assay
Select the Assay option if you want the selected (highlighted) database field to be imported as assay data.
Sample
Select the Sample option if you want the selected (highlighted) database field to be imported as sample data.
Standard
Select the Standard option if you want the selected (highlighted) database field to be imported as standard data.
Duplicate
Select the Duplicate option if you want the selected (highlighted) database field to be imported as duplicate data.
Parameters
Field name
Specify the field name. This field is read-only for required field types.
Data type
Specify the data type. This field is read-only for required field types.
Data format
Specify the data format. This field is read-only for required field types.
Dummy
Specify the alpha and /or numeric characters to be used as the dummy. The default is (*).
Related Topics
Drillhole Import Wizard:
Import Drillholes from Excel or Access Files
Import Drillholes from an ODBC Connection
