Create Modelling Results Maps
Use the Create Modelling Results Map menu option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UceObsModMap;Run)*) to create modelling maps to visualize and report the results of the target modelling process.
UXO Marine extension:
- UXO - Marine Grad
- UXO - Marine Mag
Create Modelling Results Map dialog options
Target Database | |
Name | Select the target database. This database must contain X & Y coordinates, a target ID channel, and a mask channel. Script Parameter: UCEOBSMODMAP.TARGETGDB |
Group | Select the group to process from the currently selected target database. Script Parameter: UCEOBSMODMAP.TARGETGROUP |
ID channel | Select the target ID channel. Each target must have a unique target ID number. Script Parameter: UCEOBSMODMAP.TARGETIDCH |
Mask channel | Select the target database mask channel to filter out specific targets. Only the targets with a mask (channel value) of 1 will be processed. If the value is set to 0 or dummy (*), the corresponding target will be ignored. If the field is left blank, no mask will be applied. Mask channels have their CLASS attribute set to "MASK", but any channel from the drop-down list may be used as a mask channel. Script Parameter: UCEOBSMODMAP.MASKCH |
Data Group | |
Modelled database | Select the database that contains both observed and modelled data for each target. The name will have the form "<Survey Database>_<Target Database>_<Target Group>". Script Parameter: UCEOBSMODMAP.MODELLEDDB |
Observed channel(s) | Select the channels that have been modelled using the Model Targets (Batch) option. Script Parameter: UCEOBSMODMAP.OBSERVEDCH |
Map Parameters | |
Instrument type | Select the instrument type from the list of available instruments. Script Parameter: UCEOBSMODMAP.INSTRUMENTTYPE |
Grid colour table | Select a colour table (TBL, ZON, or ITR assumed). Script Parameter: UCEOBSMODMAP.COLORTBL |
Grid colour method | Select the colour method as one of the following options:
If the selected colour scheme (grid colour table) is an .itr file or a .zon file, the colours are already attributed to data ranges, and this entry remains disabled. The "As last displayed" method will display the grid as it was displayed the last time the grid was viewed, and the colour table will be ignored. Script Parameter: UCEOBSMODMAP.COLORMETHOD |
Display residual field | Check this option if the residual map is to be displayed. Script Parameter: UCEOBSMODMAP.DISPRESIDUAL |
Modelled parameters | Select the parameters that have been estimated using the Model Targets (Batch) option. Script Parameter: UCEOBSMODMAP.MODELLEDPARAMS |
Open all maps | Check this option to display the maps as they are created. Script Parameter: UCEOBSMODMAP.DISPALLMAPS |
The Create Modelling Results Map option creates a map for each target in a target group that includes the observed (measured), modelled, and residual data as grid images, as well as a table of the selected modelled parameters. The number of maps for each target is defined by the number of selected observed channels, so you may have more than one map for each target if more than one observed channel was selected. The map files are named "<Modelled Database>_<Observed Channel>_<Target Id>.map" and are saved in the subdirectory "...\_wrk\maps" inside the project directory.
Selecting a ZON or ITR file for the colour table will allow you to control how the observed and model data are displayed, for example, to display them using the same colour range as you used for the entire survey grid.
See Also
