Calculate Axial Symmetry and Polarizability Noise
Use the Calculate Axial Symmetry and Polarizability Noise option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaCalculateAxSymBetaNoise;Run)*) from the menu AGC Expert User > Static Data Inversion to calculate axial and plate-like symmetry and polarizability noise values for each source in the source database.
Calculate Axial Symmetry and Polarizability Noise dialog options
Source database
Select the source database.
Script Parameter: UXANALYZE.SOURCEGDB
Group
Select the source group.
Script Parameter: UXANALYZE.SOURCEGROUP
Mask channel
Select the mask channel.
Script Parameter: UXANALYZE.TARGETMASK
When the GX is run, the following channels will be created/updated in the source database:
  • UXA_AXIAL_SYM: Determines a measure of how well second and third polarizabilities match for axial symmetry.
  • UXA_PLATE_SYM: Determines a measure of how well first and second polarizabilities match for plate-like symmetry.
  • UXA_BETANOISE_PTS1: Determines the number of points where the first polarizability increases with time.
  • UXA_BETANOISE_VAL1: Determines the total polarizability value for the points where the first polarizability increases with time.
  • UXA_BETANOISE_PTS2: Determines the number of points where the second polarizability increases with time.
  • UXA_BETANOISE_VAL2: Determines the total polarizability value for the points where the second polarizability increases with time.
  • UXA_BETANOISE_PTS3: Determines the number of points where the third polarizability increases with time.
  • UXA_BETANOISE_VAL3: Determines the total polarizability value for the points where the third polarizability increases with time.
  • UXA_BETANOISE_PTS: UXA_BETANOISE_PTS1 plus UXA_BETANOISE_PTS2 plus UXA_BETANOISE_PTS3.
  • UXA_BETANOISE_VAL: UXA_BETANOISE_VAL1 plus UXA_BETANOISE_VAL2 plus UXA_BETANOISE_VAL3.
