Determine Model Coherence Anomalies
Use the Determine Model Coherence Anomalies option, (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaModelCoherenceAnomalies;Run)*), to identify the approximate locations of targets from dynamic data.
A series of data-chips are extracted from the located survey data and a simple, single dipole model calculated. If a particular data-chip of data produces a good model fit, as measured by the model coherence (UXA_FIT_COH), we can assume a buried source is nearby. A grid of the coherence is calculated and can then be used to identify potential target locations.
UX-Analyze extension:
- AGC Dynamic Data > Coherence Anomaly
- AGC Expert User > Dynamic Data Prep and QC
Determine Model Coherence Anomalies dialog options
Database prefix | Select the sensor (data) database prefix. Script Parameter: UXANALYZE.DYN_DBPREFIX |
Lines to process from located database | Select the lines, which can be Selected lines or All lines. Script Parameter: UXANALYZE.LINES_TO_PROCESS |
Sensor channel suffix - leveled | Specify the sensor channel suffix. Script Parameter: UXANALYZE.SENCHAN_SUFFIX |
Gates | Select the low and high time gates from the list, which limit the range of data used when modelling the data. Default, low gate: gate value based on UXA_GateFirstValidTime channel Default, high gate: the maximum gate number Script Parameters:
Pitch channel | Select the pitch channel from the list of existing database channels. The default value is UXA_PITCH_FILT. Script Parameter:UXANALYZE.PITCH |
Roll channel | Select the roll channel from the list of existing database channels. The default value is UXA_ROLL_FILT. Script Parameter:UXANALYZE.ROLL |
Heading channel | Select the heading channel from the list of existing database channels. The default value is UXA_COG. Script Parameter:UXANALYZE.YAW |
Coherence Anomaly | |
Mesh cell size (m) | Enter the cell size for the coherence mesh that covers the survey area. It should be chosen to properly define the coherence anomalies and the typical range is between 0.1 and 0.5 metres. Default is 0.1 metre. Script Parameter:UXANALYZE.COHERENCE_ANOMALY_MESH_CELL_SIZE |
Data chip cross-line dimension (m) | Enter the data chip cross-line dimension. Default value is 1.6. Script Parameter: UXANALYZE.DATACHIP_CROSS_LINE |
Data chip along-line dimension (m) | Enter the data chip along-line dimension. Default value is 1.2. Script Parameter: UXANALYZE.DATACHIP_ALONG_LINE |
Probable source depth (m) | Enter the probable source depth. Default value is 0.4. Script Parameter: UXANALYZE.PROBABLE_SOURCE_DEPTH |
Survey line direction (deg) | Enter the survey line direction in degrees, which is between -180 and 180 and measured from the north. The Script Parameter: UXANALYZE.DATACHIP_LINE_DIRECTION |
File name suffix | Enter the optional file name suffix, which will be added to the default names for coherence anomaly database and grid: Coherence anomaly database: [PREFIX]_[DATATYPE]_CohAnomaly_[SUFFIX].gdb Coherence anomaly grid: [PREFIX]_[DATATYPE]_CohAnomaly_[SUFFIX].grd Default value is Blank. Script Parameter: UXANALYZE.COHERENCE_ANOMALY_SUFFIX |
[Adv. Grid Parameters] | When selected the Grid Parameters dialog is displayed that enables the user to set the gridding parameters for this GX. |
