Latency Correction
Use the Latency Correction option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaDynamicDataLatencyCorrection;Run)*) to correct latency errors introduced by instrument timing delays.
UX-Analyze extension:
- AGC Dynamic Data
- AGC Expert User > Dynamic Data Prep and QC
Latency Correction dialog options
Survey Data | |
Database prefix | Select the database prefix. Script Parameter:UXANALYZE.DYN_DBPREFIX |
Lines to process | Select the lines you want to process. The available options are: Selected lines, Current line, and All lines. The default is Selected lines. Script Parameter:UXANALYZE.LINES_TO_PROCESS |
Reference latency channel | The database channel to which the instrument delay is associated (see below). Script Parameter:UXANALYZE.REFERENCE_LATENCY_CHAN |
Delay (sec) | This would be similar to the Instrument Latency Correction tool in UXO Land; where the user enters a delay in time (seconds) to shift the data. Script Parameter:UXANALYZE.LATENCY_DELAY |
Original X backup channel | Specify the name of the original X backup channel (see notes below). Script Parameter:UXANALYZE.X_BACKUP_CHAN |
Original Y backup channel | Specify the name of the original Y backup channel (see notes below). Script Parameter:UXANALYZE.Y_BACKUP_CHAN |
This GX is used to help remove effects of latency errors in data caused by instrument timing delays.
Automatic Backup of Original Locations
This GX is designed so that the original locations are preserved, and are used automatically if the process should need to be repeated (for instance, if the offset direction or distance need to be altered). The methodology is as follows:
The first time this GX is run, the original locations are first copied into the backup channels; by default these are "UXA_X_Array_preLatency" and "UXA_Y_Array_preLatency". These channels are protected, and should not be altered by the user.
The GX recovers the locations from the backup channels to use in processing. The "X" and "Y" channel values are never used, except in case #1, when they are copied once (and only once) into the backup channels.
The "X" and "Y" channels are overwritten with the results of the offset calculation.
To restore the "X" and "Y" channels to the original values, you can enter "0" for the delay. The GX will then copy the original data back into the "X" and "Y" channels.
