Perform Library Match
Use the Perform Library Match option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaPerformLibraryMatch;Run)*) from the AGC Expert User > Source and Library Management menu to classify the targets against a master signature library.
Perform Library Match dialog options
Library Database | |
Name | Select the signature library. This library is a Geosoft database containing a variety of known munitions. Script Parameter:UXAPERFORMLIBRARYMATCH.SIGNATURE_LIBRARY_DATABASE |
Group | Select the library group. Script Parameter:UXAPERFORMLIBRARYMATCH.LIBRARY_DATABASE_GROUP |
Item description channel | Select the item description (ID) channel in the signature library. Script Parameter:UXAPERFORMLIBRARYMATCH.ITEM_DESCRIPTION_CHANNEL |
Source Database | |
Name | Specify the source database. Script Parameter:UXAPERFORMLIBRARYMATCH.TARGET_DATABASE_NAME |
Group | Select the source group. Script Parameter:UXAPERFORMLIBRARYMATCH.TARGET_DATABASE_GROUP |
ID channel | Select the source ID channel. Script Parameter:UXAPERFORMLIBRARYMATCH.TARGET_DATABASE_ID |
Mask channel | Select the source mask channel. Script Parameter:UXAPERFORMLIBRARYMATCH.TARGET_DATABASE_MASK |
Match channel suffix | Select/specify the channel suffix. Channel suffix will be added to "UXA_LmStat_" and "UXA_LmID_" prefixes to create match statistics and match ID channel names. Script Parameter:UXAPERFORMLIBRARYMATCH.CHANNEL_SUFFIX |
Match statistics channel | Read only field - contains match statistics channel name. Match statistics metric shows the degree of match between a target and the items in the signature library, so its size would be the same as the number of items in the signature library. Script Parameter:UXAPERFORMLIBRARYMATCH.MATCH_STATISTICS |
Match ID channel | Read only field - contains match ID channel name. Each item in this channel shows the indices of the items in the signature library associated with the match ID values. Script Parameter:UXAPERFORMLIBRARYMATCH.MATCH_ID |
Match Calculation Options | |
Min. polarizability amplitude | Specify the minimum polarizability amplitude, which is the lower bound of the polarizability values used in the classification. This value should be above or equal to zero. The default value is zero. Script Parameter:UXAPERFORMLIBRARYMATCH.MIN_BETA_AMP |
Gates - Low | Select the low gate, which will affect the match statistic. Script Parameter:UXAPERFORMLIBRARYMATCH.LOGATE |
Gates - High | Select the high gate, which will affect the match statistic. Script Parameter:UXAPERFORMLIBRARYMATCH.HIGATE |
Criteria weights - Size | Specify the size. See the Application Notes below for more information. Script Parameter:UXAPERFORMLIBRARYMATCH.WEIGHT_SIZE |
Criteria weights - Shape 1 | Specify the shape. See the Application Notes below for more information. Script Parameter:UXAPERFORMLIBRARYMATCH.WEIGHT_SHAPE1 |
Criteria weights - Shape 2 | Specify the shape. See the Application Notes below for more information. Script Parameter:UXAPERFORMLIBRARYMATCH.WEIGHT_SHAPE2 |
The library match routine reads in a library group containing polarizability data for either targets of interest (TOI) or clutter items and compares them to the modelled polarizability data in the source database.
For each source in the selected group from the source database, the matching routine compares it to all the items in the se
lected library group and generates a match statistic. The match statistic for each of the three polarizabilities are combined into a final single match statistic, or metric, based on the weighting using the following criteria:
- Size - the primary polarizability (β1),
- Shape 1 - the secondary polarizability normalized by primary polarizability (β2/β1), and
- Shape 2 - the tertiary or third polarizability normalized by primary polarizability (β3/β1).
By appropriately selecting the criteria weights, the library match can be based on 1, 2 or 3 of the polarizabilities. The match statistic ranges between 0 and 1, where 1 is a perfect match. This statistic and the library item description are each stored as array channels in the source database, labelled with the Match Channel Suffix.
The difference in the values is computed at all time gates, excluding those where the values are below the minimum polarizability amplitude. If the polarizabilities used do not exceed the defined minimum polarizability amplitude, the comparison cannot be performed and a metric of exactly zero (0) is returned.
